Philco 70 Reproduction Cabinet
If Steve ever decides to make Philco 20 cabinets, I hope he will offer both versions (plain and revised/Deluxe).
Steve, sounds like you are going to be very busy! ![Icon_biggrin Icon_biggrin](https://philcoradio.com/phorum/images/smilies/icon_biggrin.gif) There seem to be a lot of orphan Philco 20 chassis out there...
Threads: 562
...and it is a challenge, cosnidering the delicate latticework of 20's grill. And the Deluxe's shadowing front panel pattern.
Threads: 54
I think that the main issue with the grilles in the Baby Grand style Philco 20s was the plywood that they chose for the front panel. I noticed on several repair threads for those things that they used a plywood with a thick single core laminated by two thinner veneers on the inside and the outside. I don't know what species of wood was chosen for the core but regardless of what it was it's a law of wood working that a board is always weakest parallel to the grain and strongest perpendicular to it. This is why you have the veneers in a sheet of plywood laid 90 degrees to one another. When you are dealing with a fret work grill you are cutting holes in all directions so in some areas, some parallel, some perpendicular, some diagonal. so using a tight grained hardwood plywood, with lots of thinner laminations rather then thinker ones will give you the strongest grill.
Threads: 55
City: Lexington, KY
Beautiful work Steve. You're filling a valuable void since Dick Oliver passed.
Threads: 97
City: Poughkeepsie, N.Y.
Yes Steve I agree with John, Thank you for your great work!
Threads: 2
City: Southport NC
Agree very nice work. You mentioned "kit" form and I wonder how that might go. Ive seen and even purchased clock cabinets sold in kit form and heck there are entire sites that sell all sorts. Might be an easy way to find out by maybe contacting one of the big clock kit places...create an ad with all the detail and see what the response might be there. Beyond that avenue I suppose mentions at sites we typically might visit for parts etc is another. Verses setting up a standalone site is what I mean. Like this place. I could see an example there getting some interest with potential buyers.
http://www.klockit.com/depts/MantelClock...pt-37.html
Threads: 29
City: Wellborn Florida
Threads: 72
City: Linn Creek, MO
I have installed a restored chassis and speaker in the cabinet. This one will be going to my daughter.
[Image: https://farm5.staticflickr.com/4456/3722...4c44_z.jpg] 105_0811 by Steve Davis, on Flickr
I have already started on the second 70 cabinet. I am planning to post step by step pictures as the work progresses.
M R Radios C M Tubes
(This post was last modified: 09-23-2017, 12:17 AM by Steve Davis.)
Threads: 562
You are spoiling her ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif)
Then aren't we all....
Beautiful. Looks almost like it just came off the assembly line!
Threads: 562
Why almost, Ron?
'Cause you do not see the assemly line around?
Minor nitpick: A 70 Baby Grand should have a medium rosette knob for tuning, and three small rosettes (same size as the off-on knob) for volume, off-on, and tone.
But it still looks amazing!
Threads: 562
Ron
I remember us discussing it before (I asked the question as mine has what you descibe and I had doubts), wasn't it said that there were different combinations of knobs on 70? (on 90 I see only medium rosettes tone and volume and large for tuning but on 70 I see both what you have and what Steve has).
Threads: 72
Quote:Minor nitpick: A 70 Baby Grand should have a medium rosette knob for tuning, and three small rosettes (same size as the off-on knob) for volume, off-on, and tone.
Well, that is easy to correct.
Mike (Morzh)
This has been a topic of discussing, cussing, and general disagreement for some time now.
However
Based upon studying old Philco ads and the three Model 70 Service Bulletins (57, 57-A and 57-B), I have drawn the conclusion that, at least, the early model 70 cathedrals (without AVC) use a medium rosette for tuning and three small rosettes for volume, off-on and tone.
If memory serves, I believe most model 70 consoles used the same knobs as model 90 (large rosette for tuning, small rosette for off-on, medium rosette for volume and tone).
But I would have to re-research some of this to state solid conclusions (again)...and, frankly, I do not have time to do so right now.
Quick progress report:
Hi Rod,
Hello Tim,
There are currently 4852 online users. [Complete List] » 3 Member(s) | 4849 Guest(s)
