Batterymaker--PT-89 Battery?
I bought a PT-89 that had an old striped Burgess battery dated June 1948 inside it. The battery's paper wrapper is in GOOD condition--good enough to re-produce. If you would be interested in reproducing it, I will furnish the old Burgess to you to re-produce. It's about 1X4X6 and is 1.5V+60V.
Sure, have at it.
That battery's a cinch to reproduce. A couple of AA's and about 5 or 6 nine volts are all you need.
