Antenna
I have a couple of 1930's Philco car radios which I'm about to fit to 1930
vintage cars.Can any members of the Phorum recomend a good antenna?
In the 1930's some cars had the antenna mounted under the running boards.The radios will need an antenna with a lot of gain as the radios of this vintage don't have the gain of modern sets.
Look forward to replies.
