16b bakelite cap question
I'm working a 16b-code125 chassis. I have a question about caps in bakelite block #97 on schem. It calls for .3 on schem. and it is a twin cap block. #6287 F which the bakelite chart shows it should have 2-.15 caps inside.
The caps were both connected to lug 1 and then one to lug 2 and other to lug 3 with a wire jumping from 2 to 3.
Did Philco use two .15 caps in parrallel to get the .3 value?
Using capacitor calculator it shows .03 as the value.
I'm down to 2 more bakelite blocks to rebuild and want to make sure I'm clear on what values to use. Thanks . [Image: http://i1336.photobucket.com/albums/o654...5f487c.jpg]t Sorry for the poor schem.
Capacitors connected in parallel are additive. 0.15 + 0.15 = 0.30 uF
Thanks Bob. I can get it finished now.
What kind of capacitive calculator gives 0.03 for two 0.15 in parallel?
The kind when you put the WRONG values in. Going back and checking I put .015 in formula.
Lately I'm getting gun shy to ask questions on here. Seems I'm always screwing up the question.
Happens. Don't sweat it.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
