610 and 37-60 pinstriping
Can anyone help with the location of pin striping for 37-60 tombstone and 610 tombstone? I have found all the "Philco" slide-on decals, but no luck with striping.
No vintage Philco cabinet used pinstriping originally.
Models 37-61 and 37-610 tombstones originally used a large decal on their front panels which is known as photofinish. Until recent years, it was thought impossible to reproduce these finishes. However, Stewart Schooley has developed a method to reproduce a photofinish on any radio:
http://www.philcoradio.com/schooley/index.htm
A while back a gentleman in the UK contacted me about how to restore the front panel finish on his 37-60. He decided to use veneer. That took care of the fake burl as well as the chipmunk stripe. It was his first project of the sort.
Here's some pix...
http://s132.photobucket.com/albums/q18/b...%20Philco/
Philco 91 Tuning Condenser
There are currently 10538 online users. [Complete List]
» 2 Member(s) | 10536 Guest(s)
