Philco pin striping
Does anyone know where I can purchase pin striping for Philco 610 or 37-60 tombstone. Have looked everywhere and can't find them. Please help.
Hi
Question answered here:
http://www.philcoradio.com/phorum/showth...p?tid=1395
Please do not post multiple topics on the same subject.
Thank you.
Philco 91 Tuning Condenser
There are currently 10450 online users. [Complete List]
» 2 Member(s) | 10448 Guest(s)
