Arvin Rhythm chassis stickers
I took a break from Philcos and am restoring an Arvin Rhythm baby and the UL, USA and RMA yellow round stickers on the rear of the chassis are virtually gone. I would like to ask if anyone can provide high resolution photos of their stickers so I can reproduce them for my chassis? I think these would also be the same on other Arvin Rhythm, and perhaps even the Phantom series as well.
Steve D
There are currently 3202 online users. [Complete List]
» 3 Member(s) | 3199 Guest(s)
