  • 1 Vote(s) - 5 Average
mute philco 19 or 89 or all between
#61
At least now we (finally) know that this is a model 19 and not an 89. That only took eight days and four pages. Icon_rolleyes
Confused
Nice job on that cabinet.
Now the coil.
It did look like it was a ferrite antenna. Which has a differen purpose. For starters, it is an antenna. It is also a transformer by design.
The ferrite provides coupling and also changes inductance of the coils, times the ferrite permeability.
However, given right geometry of the coils, it is possible in theory to convert it into an IF transformer.
Now, the IF transfomer is two coupled resonant tanks. Each half is a resonant tank tuned to the IF frequency.
The coupling is through the "air core" so the coils need to be fairly close, compared to the ferrite coupled types.
Now the frequency is dictated by the inductances and capacitors.
The inductance is dictated by number of turns and geometry of the coil, and this is a given, so the only way to tune frequency is to variate the capacitors in parallel to those coils.
If you have a generator and a scope this is easy enough. If not, it is an exercise.
#63
Yes, Confused.. I know. They helped me alot with my 47-1230 also. As I said I was kidding around, I think most knew that. No problem here. I have been on here a while, i hope most here knows my respect for them. That doesn't mean I can't kid a bit once in a while. Icon_wink
#64
I pushed what was left of the middle out of the paper scaffold tube then moved them as close as about 1/4" after I took out the crumbled core. The core fell out followed by powder. The original was roughly about 1/8", should I move it closer? haven't put it in yet.
#65
Well here's the news.
I made the coils about the same as the original, soldered and put it all back together. I think I'm on the right track.
I got very faint noise.....whining , faint static and hissing where I got nothing before. I got it in the middle of the dial where before it was quiet.
I think I found the problem and need to get a new part. By what I've gone through with this radio it seems narrowed down to the IF coil after all.
YEAHHH!!!!!!
Now to find the part.........sad face!
#66
http://www.oldradioparts.com/2a6fla.txt
1461-222 PHILCO 89 PHILCO "89" COILS, INQUIRE... 1 0.00
I do not know if this is the one, or if he even has stock.
#67
Hey Morzh
I did check his parts listing. It Says "inquire" so I shall.
I turned it off and tried again and the hissing got a little louder.
Thanks for the info I'll need it...
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
There are currently 2099 online users. [Complete List]
» 1 Member(s) | 2098 Guest(s)
