Philco Service Bulletin PR-1100
Hello all
Still working on a 46-1201(code 125); the Philco "update" bulletin posted before helps, except that I cannot find a schematic for 46-1201 (code 121) that it refers to. It does however reference Philco Service Bulletin PR-1100 as a source of this schematic. It also says "these documents should be used in conjunction with Philco Service Manual PR-1167.".
Does anyone have a copy of PR-1100 and/or PR-1167??
Thanks in advance!
theblurrrr
I need this now also. I can't tell how my phono should be wired.
The speaker table error?
Philco 70 antenna lead
There are currently 5119 online users. [Complete List]
» 1 Member(s) | 5118 Guest(s)
