Question on 116B circuit change
Question on the circuit upgrade found in later chassis.
http://www.philcoradio.com/tech/116.htm
Should this be done to earlier versions? I haven't checked mine yet. I'm sitting at work and thinking about this.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
I would not change an older Code version. I don't see it as necessary. YMMV
