46-1201 (code 125)
Hello Folks!
Today I'm trying to repair a 46-1201(125) and I'm noticing that the schematic shown on NostalgiaAir is a 46-1201(122), which is substantially different in tubes used and other parts. Does anyone here have a schematic for a 46-1201(125), or can they point me in the direction where I can find one??
Thanks much in advance!!
Sure enough, I have discovered the question already answered on another post. Thanks for the post, Ron!
theblurrrr
There are currently 10433 online users. [Complete List]
» 1 Member(s) | 10432 Guest(s)
