Where is this dial used?
This looks like the two band 42-340 series except 14.0 does not appear on SW band.
[img]http://s286.photobucket.com/user/radiodale/library/?view=recent&page=1[img]
Thank you,
It somehow looks sort of 50's like... or late 40's? The style of the numbers is what makes me think that.
You can rule out the 41-608. This is what mine has:
[Image: http://img.photobucket.com/albums/v222/i...P/dial.jpg]
If that is a 42-340 I would love to buy it!
Kirk
As I posted, the 340's I have seen on RM all have the 14 on the dial. This one is pristine and I am willing to sell it.
I have a 42-360 and by the picture this looks the same.
Eric
Eric,
Can you post a photo of yours?
Thank you,
Eric,
No need to post the photo. I Googled the model number and and a dial photo appeared. You were correct. Unfortunately someone has shortened it to fit into a 40-190 so now it isn't useful for any Philco.
Thank you,
Here is a picture of mine if I do this right. Also my dial glass measures 9 3/8
Eric
Mine has been shortened to 8-5/8in.
There are currently 10463 online users. [Complete List]
» 4 Member(s) | 10459 Guest(s)
AvatarAvatarAvatarAvatar
