41-250 bandswitch lamp
There was a posting on 10/20/07 describing how the 41-250 bandswitch operated. The part I need help on is exactly where and how is the spring attached as mine is missing this part. I understand the spring is approx. 1/8" in dia. and about 7/8" long including the loops. Any help will be greatly appreciated.
Image that might help you
