Zenith 5S319 racetrack and AK 84 question
My set has that photo finish stripe on the right side. There are many sets being advertised without it. Does it mean production change or just a simple removal of it during the cabinet stripping and restoring? Also, has any of AK-84s come with a cabinet side switch? Thanks.
On the Zenith I think that stripe is often removed when someone has stripped the cabinet without realizing it is photo-finish.
I do not think any A.K. 84 cabinets had a factory switch on the side.  Some of the later cathedrals, like the A.K. 92, had a sensitivity switch on the side.  However, it was not uncommon for someone to mount a switch on the side of a radio to replace the factory on/off when it went bad.
The speaker table error?
Philco 70 antenna lead
There are currently 1833 online users. [Complete List]
» 2 Member(s) | 1831 Guest(s)
