The best table top Philco
Philco 49-909 for me...because it's been in the family since it was brand new.
I would vote for the 48-482 because it covers AM, FM and SW. With so little to listen to on AM these days, having FM is a definite plus. For a late 40's model, its an exceptional performer on FM when restored and aligned properly
[Image: http://www.wa2ise.com/radios/philco401.jpg]Though not that sensitive, it does look cool, as it's unusual.
Or
[Image: http://www.wa2ise.com/radios/ph46-806.jpg] I got from Peru via ebay...
Or
[Image: http://www.wa2ise.com/radios/ph50_922.jpg] this is a classic.
I like the 59c for looks and compactness; and the 48-482 for performance (although is almost big enough to be a mini-console Icon_surprised  ).
