Philco Grandfather clock 570 Clock Motor
Hello, I need a replacement motor for the electric clock in this particular model. Could someone please advise with the best place(s) to possibly obtain one, or get information on this? I would appreciate it. Thanks, Brad J.
Welcome Brad. Are you sure the motor is bad?
There's a start knob that you turn with your fingers to get it going.
The knob sticks out the back of the motor.
Plug it in and spin
Tim
There are currently 3070 online users. [Complete List]
» 2 Member(s) | 3068 Guest(s)
