Philco Grill Cloth
HI All
What is the pattern of the grill cloth in a 37-675? It looks like chevron in the galley picture. Is that correct?
Is there anyone making a repo? If so who is the best?
Thanks     Joe  Icon_biggrin
Kenny Richmond makes chevrons and some others, sells on eBay.
Yes, Kenny's Philco Chevron cloth is what you want.
http://www.richmonddesignsinc.com/
(his website seems to be down as of this morning...perhaps a Yahoo issue?) Edit: It's back up now.
You can also find his cloth on eBay; look for the seller name richmonddesignsinc .
Icon_thumbup Icon_thumbup
Thanks guys.
Joe
There are currently 10218 online users. [Complete List]
» 3 Member(s) | 10215 Guest(s)
