Philco 89 Dial Cord Routing
I need a sketch or a few photos.
Thank you,
I figured it out. Once the routing was correct the tension became critical. Working fine now.
There are currently 5686 online users. [Complete List]
» 2 Member(s) | 5684 Guest(s)
