What model do I have???
I just opened up a recent purchase of a Philco and I'm not sure exactly what I have. The label on the inside says it's a model 66. However, there is a hole in the chassis where the 80 rectifier is indicated on the label and looks like nothing was ever mounted there. On top of the power transformer is an integrated tube socket, but definitely not for an 80 tube as it is an 8 pin socket (and empty). Some auction pics of this set needing some cabinet attention is here:
http://cgi.ebay.com/350112163848
Another thing I don't see in looking at it is a dial light, or mounting brackets whatsoever. Does anyone have a picture of a chassis that might be like mine they could post to see what's supposed to be there? Thanks!
It sure looks like a model 66. Someone rewired the 80 rectifier tube for the more modern 5Y3 which is electrically the same. It's not an unusual modification; I've done it many times in the past.
Pete AI2V
Thanks for the info - I'm guessing then the transformer was replaced as well since the socket looks to be incorporated on the top of it?
In addition to what Pete has already stated, I would add that it appears someone used a 1937/38 Philco transformer with integrated octal rectifier tube socket on top to replace the original vertical mounting power transformer, and removed the original 80 rectifier socket.
If I don't forget, I'll try to photograph and post some photos of my Model 66 chassis sometime over the weekend, for comparison.
Thanks Pete and Ron for the info. Hopefully the wiring isn't too buggered up inside, haven't pulled the chassis. The cabinet alone needs a lot of love as it is Icon_lol
Ive had to replace a few orig broken octal-sockets mounted on orig Philco trans before, not fun!! Icon_wink
Here's your dial lamp assembly.
-Bill
[Image: http://www.sparkbench.com/66diallamp2.jpg]
And here are shots of the Model 66 chassis, showing the correct vertical mounting power transformer.
Front view:
[Image: http://www.philcoradio.com/images/phorum/66_1.jpg]
Top view:
[Image: http://www.philcoradio.com/images/phorum/66_2.jpg]
Back view, just for the heck of it:
[Image: http://www.philcoradio.com/images/phorum/66_3.jpg]
Notice how, from the top views, the Model 66 chassis looks identical to a Model 60 chassis. The only thing that gives it away is the different dial scale which covers 4.2 to 12 mc shortwave in addition to AM. Underneath, however, the parts layout differs from a 60.
Thanks to both for the pictures. The dial lamp assembly looks pretty basic and should be able to come up with something when the time comes. I wasn't sure if it was one of the more involved type with the reflective hood and all.
Philco 91 Tuning Condenser
There are currently 10119 online users. [Complete List]
» 2 Member(s) | 10117 Guest(s)
