66B band switch question-SOLVED-
Threads: 113
City: The Villages
I don't know if anyone remembers, but a while back Morzh and I were trying to figure out the best way to free up the band switch. After a lot of work we were both able to get them freed up.
Now, my question: while I have the switch moving freely and switching properly, in my zeal to free it up I no longer have a stop. In other words, the switch now turns a full 360 degrees instead of stopping after one click to the right and one to the left.
Any ideas on what the stop is and what it looks like and where it is located?
Eric
The Villages, FL
Threads: 55
City: Evanston, IL
It should be right against the detent front plate.
The tab may be broken off and you can't recognize it?
Probably not an adjustable stop plate, but a tab preset.
Tab must be gone, if swx rotates 360.
Threads: 563
Eric.....yeah, man, hate to break it to ya, but as Chick said (and you probably suspected it all along when you said something about "your zeal to free it up") you had likely broken some sort of a tab.
Which considering the degree of seizing (two hands effort and Robo-grip pliers produced little if any movement....what did they use for lube, Liquid Nails?) is something no one should be blamed for.
I do not remember how this thing looked exactly (I liked the idea of it coming out completely when the retention ring was removed...oh, wait....I did not have any retention ring ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) ) but if it had some sort of rib or a peg, you could (now that you can pull it out) in case of a peg drill a little hole (carefully not to break it) and glue in a cylindrical peg of some rigid insulating material, or if it is a a rib, simply glue a small bar of something along where the original was.
If you could produce a photo of what you have and point to the place of where the stop was we could brainstorm it here.
Of course it might be not on the rotor, but on the stator.....same thing, get a photo.
Threads: 113
City: The Villages
Yup. That's what I was afraid of. Now I just have to find out where it was and what it looked like.
Eric
The Villages, FL
Threads: 563
Yep. Why don't you find out where it was and what it looked like.
Suerte.
Threads: 113
City: The Villages
very funny
Eric
The Villages, FL
Threads: 113
City: The Villages
Well guys, thanks to you I figured it out. I pulled out the shaft and I could see where the stop was. I drilled a small hole in the Bakelite just below where the original was in the switch body. I super glued a small pin in the hole and...son of a gun! It works
Thanks, guys.
Eric
The Villages, FL
Threads: 563
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
