116b speakers
I recently picked a 116b with the 10.5 inch speaker. The service info calls out an H13, this speaker is a 10.5 inch but has LL14U printed on the frame. Is this an aceptable substitute? The cord and plug appear to be factory original. Thanks Hank
hank
welcome to the phorum
sam
If the field coil is the same or close to spec, speaker fits in the cabinet correctly, and sounds nice, you're good to go.
Ditto.
There are currently 9757 online users. [Complete List]
» 1 Member(s) | 9756 Guest(s)
