Mystery Control
Hey all, I received a Philco Mystery Control from a guy I do some trading with every now and then awhile back. I repaired the spring, and followed a guide about how to flatten the tinite dial since it was warped. Anyone know what color would best match the dial? After placing it in the hot water and getting it flat it discolored. Thanks guys
The thankful receiver bears a plentiful harvest.
