WHY IS THIS HAPPENING TO ME!?
These things keep following me home!
For $20 why not.
It has the 9 front posts as well just not in the pic.
Icon_crazy
[Image: http://i1289.photobucket.com/albums/b519...pn1pfm.jpg]
Must be just bad luck on your part? Really a great price and the exterior looks great. The bezel appears to be that famous plastic and might have a piece on the corner missing. Not certain if there are repos for this model available. Nice find.
Jerry
Nice find for the price. Good luck on the restore.
 Yes, there is a reproduction escucheon available, the 8 pushbutton escutcheon for the 1941 models is available, and the 9 pushbutton ones for the 1942 models is also available. They cost about three times more then this radio cost, four including new buttons and knobs, but the real cost is going to be time spent replacing the rotted rubber wire.
The escutcheon Arran mentioned can be found at Radiodaze.
Why???  Because you did such a nice job on the last one you restored.  Icon_smile
Philco Karma
There are currently 6990 online users. [Complete List]
» 1 Member(s) | 6989 Guest(s)
