38-2670 cabinet problem
You can install veneer on a sharp radius horizontally by soaking it in veneer softener and using the cabinet as a form. Once dry you can trim and install it. They used steam in the old days......some cabinet makers still do although most use bending irons, heat blankets and vacuum forms. I'm sure there are other ways as well.
Ok,
Here is the finished cabinet guy's.[Image: http://i1161.photobucket.com/albums/q509...abinet.jpg]
looks great murf Icon_clap
That turned out very nice Icon_thumbup
Great save murf!!!  Looks great  Icon_clap Icon_clap Icon_clap
Very nice!
Murf, what a great job. Congrats
Jerry
There are currently 11402 online users. [Complete List]
» 2 Member(s) | 11400 Guest(s)
