K6 speaker cone replacement question
Apologize if this is elsewhere but I didn't see it in a search. My K6 speaker cone is beyond repair. Half of it is ripped out, the other half is torn in several places. Before I order a replacement I want to see if someone could verify the size:
8", 1.5" opening?
This may be in the materials I ordered from Chuck Schwark but I just ordered those, meanwhile I found a place for really inexpensive cones.
The thankful receiver bears a plentiful harvest.
where did you find inexpensive cones....I've got one that's a basket case
