116X alignment tools
The 116 x chassis has nuts that have to be adjusted during alignment, where can I find a plastic tool for this procedure or what do you use to do this. Metal sockets drive the radio crazy.
hi ron
do a phorum search on tool
sam
Ronin
Many of us made one from a plastic ballpen, by heating it up and morfing it around a proper size nut or standoff.
(11-16-2014, 06:15 PM)morzh Wrote:  Ronin
Great idea. I've ran into this same problem before.
The ballpoint pen trick worked like a charm, you guys are the best , the 116x is working like a champ.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7199 online users. [Complete List]
» 1 Member(s) | 7198 Guest(s)
