New to Phorum and a Philco 38
Hello all, I just registered to the Phorum tonight, after the purchase of a Philco 38. The radio had been converted to AC at one point, then sometime after that the transformer failed. The previous owner then removed the TX with the thought of replacing it but never did.
So, my challenge is to restore it back to being a battery set as it should be. This is only my second Philco, my first being a Hippo. I really like the styling of this set, and look forward to getting it going.
I suspect that I will need to post questions in the future as I begin this project. I'll take some photos and post them also.
Russ
radioalfa
welcome to the philco phorum
sam
 Hopefully the previous conversion attempt did not butcher the chassis too badly, which is often the case when someone tries to convert a battery set into an AC set. The styling is very much like a Philco 60B, which has five tubes but one is a #80 rectifier, it looks like the model 38 used a type #15, a #32, a #32, a #30, and a #19, so probably about the same performance wise in the front end, although the #19 output will probably make it sound pretty good.
Hi Russ and welcome to the Phorum!!
I've always liked farm sets, something about being off the grid or the grid is nowhere near you. The original owner probably spent many nights listening to this set without an electric light just him and a kerosene lamp. Shadows all around odd noises kinda spooky! In 1935 lots of good shows on the airwaves Fibber McGee & Molly was just starting out while Amos & Andy, The Shadow, and Calling all Cars had been well established by then.
Hopefully someone here has a 38 chassis that can be seen so you can have something to go by other than just the diagram. Sometimes the parts placement can be a little critical so some pics can really help. Sorry I don't have a 38.
Best of luck w/it
Good thing about going back to battery set is you don't need no stinkin' transformer, or ballasts.
You connect all the filaments together, remove the rectifier and toss the bad power transformer, then wire the battery cable back which is also pretty straightforward.
Welcome to the Phorum!
Hi pholks, thanks for the welcome, tips,and encouragement. As I mentioned I will get some photos soon, hopefully later tonight.
Russ
I have had some time to look at the 38 more closely, here is what I know so far;
As I mentioned above, a conversion had been done to allow the radio to operate on AC, but the transformer failed and the previous owner removed it.
Two tube sockets have been removed, type 6 and type 30.
Other tubes
Type 19 replaced with a tube with no markings
Type 15 replaced with 6A8 G
Type 32 replaced with 75
Type 32 replaced with 78
With the exception of type 19, all other tube sockets have been replaced.
A multi section electrolytic has been added
Holes have been drilled for TX, along with some other miscellaneous holes
Has "newer" wire and some caps
I have some pictures, and will set up an account online so they can be viewed in the next couple of days.
Russ
 The #19 uses a six pin base, so they may have used a #41 or #42 in it's place. The #30 has a four pin base, as does the two #32 tubes, if there was a type 6 tube in your set that was a four pin ballast, which means the set was actually a 38A. The type #15 had a five pin base, the 6A8G is obviously an octal. So yes, there was some butchery that went on with this set.
Here are a few photos of the 38.
Russ
 Thankfully the IF cans and front end coils still seem to be in place, along with all the trimmers and padders, and the tube shield bases, unfortunately they pulled out all of the Bakelite block condensers and added a bunch of stuff that the model 38 would never have had. It looks like this was indeed a model 38 and not a 38A as there is a hole for a ballast socket but no evidence that a socket was ever installed. I really hate it when people attempt to convert battery operated radios into AC sets by installing AC tubes, it almost never works out well, and all they accomplish is to take an all original set with at least some historical value and make it into a parts set. It's so much less effort to rebuild a battery set as is, and then build an off board AC operated power supply to supply the correct voltages.
Hi Arran, thanks for your reply. I agree also, it is much better to use a battery eliminator for a DC set than to convert it to AC.
It looks like the type 6 ballast tube socket was there, I can see that the rivets were ground out. If I am understanding things, a 38 would have had the socket, but a jumper would have been placed across the filament contacts. Does that sound right?
Given what you see here, do you think a restoration back to DC is reasonable?
I think my first plan should be to use the schematic to create a point to point wiring diagram, and secondly to see if I can even locate the proper sockets.
Russ
(11-26-2014, 09:15 AM)radioalfa Wrote:  It looks like the type 6 ballast tube socket was there, I can see that the rivets were ground out. If I am understanding things, a 38 would have had the socket, but a jumper would have been placed across the filament contacts. Does that sound right?
That is correct. I've owned a few model 38 sets over the years; all of them had the socket for the #6 ballast, but all had a removable heavy jumper wire across the filament pins of that socket. The stickers on the back of the chassis indicated "CHASSIS TYPE 38" and not "38A".
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
There are currently 2217 online users. [Complete List]
» 3 Member(s) | 2214 Guest(s)
