Philco Radio AR-75 ? Help with ID
I picked up a green box at an estate sale that says Philco Radio in raised chrome on the front and a small tag on the side that says model Philco AR-75. It has two wires coming out and two places for connections on the bottom. It also has heat vents and several holes for adjusting small screws inside. There are no dials or nobs for tuning or adjustment. Any help on the identification would be appreciated. Thanks, Bill
Maybe this question is not appropriate for this board. Please let me know and I will not post any longer. If the question is OK, maybe a picture would help - since my description is a little vague.... thanks, Bill
It's an auto radio from 1941 model year. Runs on 6 volt DC, NEG ground systems.
Chuck Schwark Wrote:It's an auto radio from 1941 model year. Runs on 6 volt DC, NEG ground systems.
Chuck,
Would there be a separate control unit for this radio?
http://www.nostalgiaair.org/PagesByModel...013925.pdf
Carl
Northern Panhandle, WV
I believe there would be an under-dash control head and the main chassis was usually up on the firewall somewhere.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
