Another project 38-10T
Here's my latest project. This thing is much larger than I thought it would be. The cabinet is in pretty good condition no water damage. It clearly needs a speaker, field coil and a dial.  I will post in the parts wanted section for a replacement.
The underside looks like a virgin.
I am sure there will be questions forth coming.
Looks like a good project. Nice and roomy under the chassis. The photo finish might have to be redone. I have stayed away from some radios because of it. I have seen some on here that were redone and look really nice.
Chris,
When you are ready, here's the place for faux-finish . For grill cloth, try Richmond Designs. Good luck Icon_clap
Eric
The Villages, FL
Refaux is good but follow the directions!
I would try restoring it first. Original always looks better.
The Richmond Designs has some nice cloth patterns but I don't which one came on this set. I have seen some 38-10T pictures with a horizontal pattern.  None of Richmond Designs pattern have this horizontal pattern.
And the front is in pretty bad shape. It's lifting all around the edges. I saw that replacement faux-finish stuff and was wondering if it was any good. I had even considered using real veneer but I have never done inlay.
 The original speaker being AWL would have turned me off of this particular radio, along with the wiped dial scale, the faux finish less so, but I guess it depends on how much you wanted a Philco bullet model. My preference would be for one of the larger bullet models with the real veneer on the front but I would not turn down a 38-10T for the right price and condition. Right now I have so many sets to restore, table and console, that I've needed become a lot more fussy about what I buy.
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
There are currently 3094 online users. [Complete List]
» 7 Member(s) | 3087 Guest(s)
AvatarAvatarAvatarAvatar
