what are these Philco's?
Thanks, I will  Icon_twisted
Kirk
If you can go get them at minimal bother, I think it would be OK. Shipping these reliably would be at least as much as the asking price. Curb picking is getting slimmer as t he economy worsens.
There are currently 5703 online users. [Complete List]
» 2 Member(s) | 5701 Guest(s)
