46-1209 Electronics
Z, you have listed the P/N of the caps. Easier to log the value of the caps required such as .003 etc. The style you show are just fine. Depending on how many radios your planning to do, it is often better to buy kits with quantities of a given value. Alternately buy just what you need. You will find people selling caps. One I like for simplicity is Sal's Capacitors but there are many others.
Jerry
http://www.tuberadios.com/capacitors/
I believe I have a parts chassis around here. Let me know if you need some parts, I'll see what I have.
Very Nice! I have a 46-1209 in the dining room waiting for me to finish the 42-3456 I promised to get done last year (!). I sneaked a peek at the cabinet and need to know if the "birds eye" band just below the top is faux or real wood.
