battery P-274
hey guys
I am looking for info for  P-274 battery  seams to be nothing on internet about them
need one for a philco E-678 portable  radio need schematic to
thanks sam
If you can give me the voltages for the B section and A section of the battery pack, and the dimensions of the area it fits, I can explain how to make yourself a suitable replacement. I guess you will have to get a schematic first to find that. Also, you might try posting this in the "electronic repair" section. It might get more notice by the electronic restorers. You can see how I rebuilt the battery for my own Philco portable here : http://philcoradio.com/phorum/showthread.php?tid=10725  and here : http://philcoradio.com/phorum/showthread.php?tid=10728  . Best of luck with this project.
Agree, get schematic, find out voiltages needed, and you can put together inexpensive 9 volt batteries for B+ and a couple of C or D batteries for filaments, and AA's for bias if needed. Else you can build easily a plug in battery elimiter, tons of stuff here and on web. Posts already given are great advice!
