Philco 16b is alive!
     This cabinet has had been salvaged , and I must say rather well Icon_wave
Fred,
Excellent work, encourages me to restore my 16B tombstone that is painted an ugly barn red before I obtained it for $25. How did you redo the photofinish- did you replace it with veneer? Have a couple of holes in the side of mine where someone bolted the speaker after they removed it from the front? The cabinet wood on mine is in good condition.
Also, my chassis is in very good condition and not rusted. Best, John
I don't think 16 would use photofinish...would it? I always thought a high end radio such as 16 would only use veneers.
None of the Model 16 cabinets used any photofinish.
As Mike correctly pointed out, the 16 was one of Philco's high end models and as such, its cabinets used real wood veneers, not photofinish.
My apologies... I went to the garage and looked at the beat up front panels with a flashlight and they are veneer. They are in bad condition and jumped to a conclusion that they were photofinish. You would think that I would know better
than to jump to conclusions after all these years.. Icon_redface John
Excellent job Fred!
You've sure been busy Fred!!! Great job.
 Unfortunately for a high end radio Philco still went rather cheap on these, the only higher end veneer is on the raised portions on the front panel, whilst the rest of the cabinet is poplar or maple veneer sprayed with dark shading lacquer, which is often badly flaking by this time. Between the 16B cathedral and the late version of the 116B all of the other '16B cabinets were designed along those lines.
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 3017 online users. [Complete List]
» 2 Member(s) | 3015 Guest(s)
