Question on output tubes for the 37-116
The schematics and other info I have clearly states the 37-116 uses 6B4G output tubes. My set has 6A5G output tubes. Both tubes are the earlier marked PHILCO etched into the base. Also, the cabinet info sticker states 6A5G output tubes. Now, I assume there may be differences between earlier and later models? Can anyone clear this up?
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Yours is a later production, Code 126 receiver. This change is mentioned in the free "Philco Changes In Models" package I have available here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
According to the Changes In Models packet, the cathodes of the 6A5G tubes are grounded, and the hum control rheostat (128) is eliminated.
Thanks Ron. That answers that Icon_wink
-Brian
Philco 91 Tuning Condenser
There are currently 9827 online users. [Complete List]
» 1 Member(s) | 9826 Guest(s)
