early Philco 620 #73 ? watt
  Just another newbie question,,Philco 620 early model --part # 73 --- 33-1200 ---330,000 ohms resister ---is what --   1/4 watt  ??? ,,or something else,,from looking at that section of thee schematic,,,I presume that a 1/4 watt will be fine,,,am I right,,,Thank you all again for your help,,,Ken Icon_crazy
A quarter watt will do fine.
For the future please give link to sch.
(01-24-2015, 11:23 PM)morzh Wrote:  A quarter watt will do fine.
 Thank you, Philco page 6-25,,,page 6-26,,thanks again
Hi Kenneth, morzh means a link to the schematic on nostalgiaair.org.  That just makes it easier and quicker for someone to respond to your question by providing them with easy access to the schematic.
There are currently 5993 online users. [Complete List]
» 1 Member(s) | 5992 Guest(s)
