The radio I left behind.
I thought I would share a picture of the Atwater-Kent 60 I was offered along with the Radiola 50 I bought. This radio is in no danger and I decided to exercise self control and ONLY go for the radio I was called in to look at.
Nice radio and great control. As long as the radio is not going to the dumpster. Ya can't save them all and room is of course an issue. That radio should make someone happy.
Jerry
Definitely hard to pass up, but good luck with the Radiola.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
