Selenium Rectifier Replacement
Threads: 31
City: Lapeer
State, Province, Country: MI
I am gathering parts for a little Zenith L403 ac/dc radio from the early '50's. It has a selenium rectifier (Zenith p/n 212-5), and says it's rated for 75 ma, no more info. Will a 1N4007 be able to replace that? Should I even replace it at all? Anyone have a suggested replacement? Thanks!
Joe
Threads: 567
You could test it, it is after all a semiconductor rect bridge, nothing more.
Otherwise, yes, 1N4007 are good, not sure if you need to account for voltage drop, if you do, a resistor in series will do.
Threads: 31
City: Lapeer
(02-15-2015, 06:14 PM)morzh Wrote: You could test it, it is after all a semiconductor rect bridge, nothing more.
I knew that YOU would have the answer for me. Thank you friend!
Joe
Threads: 416
City: Boston
When those Selenium Rectifiers fail they get very hot and really let off a stink. I would replace it, then you can enjoy without worry.
Threads: 567
Name me one eectronic component whose magic smoke smell like petunias
Threads: 31
City: Lapeer
(02-15-2015, 09:09 PM)Paul Philco322 Wrote: When those Selenium Rectifiers fail they get very hot and really let off a stink. I would replace it, then you can enjoy without worry.
Thanks Paul. Parts are on order and I finally did locate a source that states a 3W 300 to 330 ohm resister in series to make up for the voltage drop. Joe
Joe
Threads: 416
City: Boston
I have a red one of those lil Zeniths.
Threads: 113
City: The Villages
I've done quite a few Zeniths with the rectifier. I use either a 5W 100 or 150 ohm resistor in series and I've never had a problem.
Eric
The Villages, FL
Threads: 31
City: Lapeer
Paul, Mine is a grayish-white, belonged to my Aunt.
Eric, Once it is recapped, I'm going to measure the voltage off the rectifier, put in the 1N4007 and play with resister values. Thanks for the tip!
Joe
Threads: 18
Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
Threads: 31
City: Lapeer
(02-17-2015, 10:58 AM)codefox1 Wrote: Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
Only 4 tubes in this radio, three 1 volt and one 3 volt.
Joe
Threads: 54
(02-17-2015, 06:13 PM)Joe Rossi Wrote: (02-17-2015, 10:58 AM)codefox1 Wrote: Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
No, you need to calculate the proper size resistor in this case, it is much more critical then in a regular AC radio. Each tube needs 1.4 volts, not 1 volt, and the 3 volt one is actually 2.8 volts, too low and the set won't work properly, too high and the tubes burn out prematurely, so 7 volts ideally. If the original selenium rectifier is still working do some voltage measurements to see what the output voltage is before it gets to the filament dropping resistor, and after it.
(This post was last modified: 02-18-2015, 12:44 AM by Arran.)
Threads: 567
I lost you guys, it looks now as if you are talking of filament voltages, but then what does the rectifier and the resistor have to do with it?
Threads: 31
City: Lapeer
(02-18-2015, 12:38 AM)Arran Wrote: (02-17-2015, 06:13 PM)Joe Rossi Wrote: (02-17-2015, 10:58 AM)codefox1 Wrote: Voltage increase is usually insignificant in AC/DC 5 or 6 tube sets. I'd add a 22 ohm 1/2 watt or 1 watt fusister or better yet a proper fuse to the set.
Thanks Arran. I was aware that the filament voltages are 1.4 and 2.8 volts. I referenced them that way to indicate that the set only has 4 tubes a 1R5, 1U4, 1U5, and a 3V4, and atypical to some of the older 5+ tube AC/DC sets. There is already a 180 ohm 4W and 1750 ohm 5 watt just north of the rectifier. I want to be sure that in replacing it I have the proper voltage between SE1 and R13. Thanks again, input is always appreciated! Joe
Joe
Threads: 18
Sorry for possibly misleading anyone, (should have looked at schematic before typing,) and agree that in an AC/DC/BATTERY set, the end of the voltage divider feeds the filament string, and it is VERY important to do whatever is needed to get that final voltage correct. Even before restoration sometimes the filament voltage is too high with today's line voltage and an increase in the first an last resistor in the chain can correct the situation. This is doubly important when replacing a blown 117Z3 or equivalent in similar sets.
This is my thread on 60 from 2016.
I had to rewind the osc coil, and I actually counted the turns and then rewound i...morzh — 03:34 PM |
Yes, Mark belongs to the same Michigan Antique Radio Club that I do. I suspect that the oscillator coil is in need of a ...Radios1340 — 03:10 PM |
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I...morzh — 02:51 PM |
Cool gadget, Buzz.
I took me a couple of second to undestand that that oscillating thing makes the wire to spool correc...morzh — 02:50 PM |
My back hurts already, you could build a house with all the wood. PaulPaul Philco322 — 02:49 PM |
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
Yes, standard alignment procedure. I can get the minuscule tone to vary when adjusting the trimmers. But you almost have...Radios1340 — 01:40 PM |
An imposing-looking radio, for sure.morzh — 12:43 PM |
Model 60 struck again :lol:
Welcome to the Phorum!
Above is the article on Model 60. Could be of some use.
Now...morzh — 12:38 PM |
There are currently 10732 online users. [Complete List] » 3 Member(s) | 10729 Guest(s)
