Philco Choke
HI Ron
I have a philco choke the number is 32-7491N do you have any info on this part? I need the milliampere rating. Icon_think
Thanks Joe
I'll check tonight.  I have to check another transformer already.
Have to dig out all my Philco parts catalogs from mid-30s to 40s
when I get home tonight.
Chuck
(02-16-2015, 04:04 PM)Chuck Schwark Wrote:  I'll check tonight.  I have to check another transformer already.
Chuck
Thanks Chuck
The choke is from a 37-116 the small one item #120 on schemtic
Thanks Joe
Here you go:
Filter Choke 32-7491N
7.5 H. inductance
Rated for 50 ma. DC
DC resistance 400 ohms
Chuck
Thanks Chuck
Joe
You're welcome - glad to help.
Chuck
There are currently 5022 online users. [Complete List]
» 1 Member(s) | 5021 Guest(s)
