Honest assessments, please: First refinish job
Some good advice for guys new to grainfilling is try any product first on sample boards. Veneer is relatively cheap and its easy to stick a few varieties to pieces of plywood or even correctly prepared mdf. Often grainfillers need some thinning to behave correctly and its better to work out "material kinks" before you get caught in some hideous material nightmare.
And yeah I understand.."why do you need training wheels". LOL. Mainly Ill do samples with anything new and its also nice to note which color grainfill and toner etc.
On a scale of 1-10, I'd give it an 11 or 12!!!
If my first cabinet comes out that nice, I will be quite satisfied.  Nice job!
Craig R.
The speaker table error?
Philco 70 antenna lead
