philco pot taper designation
I see that Philco potentiometers have "a" taper and "c" taper designations (and probably others). What do these mean as far as linear, log etc.?
Bob
There are currently 7448 online users. [Complete List]
» 2 Member(s) | 7446 Guest(s)
