OUCH! Its legs have been amputated!
http://cgi.ebay.com/260341918375
"As you can see in the pictures, the cabinet is in good condition, not perfect condition..."
Gee, ya think?
This would be a really nice radio if it still had its legs and stretcher base.
ebay seller "lostinthesauce" 'splains it all indeed! Off about 7-8 yrs trf design too boot. I think I saw the legs for that radio awhile back at a local flea-mkt on a funny lookin homebrew coffeetable someone had special engineered? Not sure tho. Icon_wink
Hey, I emailed that person and told him that the legs were missing. It amaizes me how people can butcher up nice things like that. I guess you could use it as a oversized table radio. Ha Ha!!
David Regira
I emailed the seller also. I see they have revised the description to mention the missing legs.
I found a Philco 96 in an antique shop a couple of years ago that was missing the legs. They were asking $200.00! When I told them the news they just shrugged and walked away....
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
...and it's probably still there, still priced at $200. Icon_rolleyes
Philco 91 Tuning Condenser
There are currently 9795 online users. [Complete List]
» 1 Member(s) | 9794 Guest(s)
