Philco 90 rests on top 23x
I just fixed up this philco 90 and thought it would look nice resting on top of the elusive philco 23x. It will not rest there to long to avoid any damage to the top of 23x. This picture of the to together like this is as rare as the 23x is. Thanks for looking at this one of a kind setup. Fred Taylor
I love shiny mershons...
That's what she said
Looking good Fred!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3052 online users. [Complete List]
» 2 Member(s) | 3050 Guest(s)
