What year, make and model do I have??
I have aquirred the family Philco. Have no idea about what year, make or model it is. Can someone help with this please??
mb
Hi MB
Can you post a picture? As Philco made literally thousands of different radios over the years, this is the only way we will be able to identify it for you. If you can e-mail a picture but can't post it here, send it to me at mr.philco at yahoo dot com and I will identify it here for you.
42-380 code 121 This is what it says on the inside. Does that help?
Yup!
Model 42-380 is am AM/SW console (floor model). A 1942 model, it was introduced June 1941.
Here's what it should look like:
[Image: http://www.philcoradio.com/gallery/image...42380x.jpg]
(Photo credit: David Kasabo)
Yep that is it. Now I need some replacement parts. It has a broken faceplate (glass) and one of the four knobs is wood. Have any parts like that?
thank you
mb
I don't stock parts to sell, but here's where you can find them:
Reproduction dial glass: Radio Daze.
http://www.radiodaze.com
Reproduction knobs can also be had from Radio Daze, or straight from the maker, Old-Time Replications.
http://www.antiqueradioknobs.com/
Used knobs are also available from at least two sources:
Mike Koste - gokmike AT gmail dot com
David Frush - parts2many AT aol dot com
Anytime you are looking for parts sources, just look here:
http://www.philcoradio.com/resource.htm
There are currently 9228 online users. [Complete List]
» 2 Member(s) | 9226 Guest(s)
