610 help
#31
Thanks guys, I don't think I would have caught my mistake.  Resistor 42 should be 32K but when I made a new dogbone I put in a 3.2M resistor and painted it orange/red/orange.  I thought I double checked all of my resistors but  probably only looked at the first two digits.  I just put in a new 32K resistor and the radio works!!!!!!!!!!!!!!!!!!  Now I just have to do an alignment.
Keith
#32
Great Glad to hear you got it working.
Been there, done that!
#34
Me too.
Congrats! Icon_clap Icon_clap
There are currently 6067 online users. [Complete List]
» 2 Member(s) | 6065 Guest(s)
