Speaker and tubes for a Knight radio
How about the cap itself, have you lubricated the shaft? That sometimes is tight....
I lubed everything. It must have grit inside but it really just feels like something is really off. VERY hard to turn the actual drum, tuning cap turns good.
Kirk
I'm pretty sure that the tuning cap is brass and not pot metal/aluminum. That's a good thing! I picked up a Crosley Bandbox battery set at a radio auction only to find that all three tuning caps are badly deformed. Think I'm going try installing ones from a AK set I've got a few spares.
I don't really remember how it comes apart (SG-8) As it's been three or four yrs ago. I think that the drum rides on pot metal bracket and that is where the binding is occurring. I was able to lub and just keep moving back and forth. Got it to the place that it was useable but still a little stiff.
GL w/it
Hey Terry,
These look so promising for the Knight but the measurement are so off. I have to re-measure mine to see if I screwed up.
http://www.ebay.com/itm/121620823735?_tr...EBIDX%3AIT
(04-18-2015, 08:34 AM)OldRestorer Wrote:  Hey Terry,
http://www.ebay.com/itm/121620823735?_tr...TRK%3AMEBI
Measurement???? dial cord??
Keep your eyes pealed for a cheap Radiola 100 speaker at Ktown. Looked on epay prices are way too high!
See you in a few weeks.
kirk
you have a speaker that will work in last pic of your garage
[Image: http://philcoradio.com/phorum/attachment.php?aid=6969]
sam
Dang! I better stock up on Mohawk stock!!!
lol
Yes I have the RCA 100 speaker but dont like the look.
Will find one eventually.
Kirk
The RCA and Radiola speakers are very different looking. You want the Radiola R-100.
There's info on this radio: http://www.radiomuseum.org/r/allied_rad_..._sg_8.html
Also, to open up your speaker possibilities a bit, since this has a P-P output, you can use a P-P output transformer that works for 6K6's and then use any 4-32 ohm speaker you like.
The speaker table error?
Philco 70 antenna lead
