Model 41-250 dual 370 pf cap
Well, I replaced the dual 370pf dual cap in the oscillator circuit with two individual 360pf caps and now the oscillator doesn't oscillate on the push button position of the band switch. On all other bands the cathode of the oscillator is grounded and the dual cap does not come into play. I measured to old cap and besides the 370pf between each of the sections and ground, there is a 170pf between the two 370pf cap sections. So, I added a cap between the the two individual replacement caps, and now I get a oscillator signal on the push button band. Has anyone else who has worked on this or similar models, and replaced the dual 370pf cap with separate units, had the same problem? Thanks.
Harv
Never had that problem. Replaced lots of 'em. Sure you have the caps connected correctly?
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
They are in correctly, so I was surprised when it did not work. I thought that maybe Philco used the coupling between the two sections to provide coupling for the oscillator, since the cap is quite large for a 370pf unit.
Harv
Your question Terry led me to take a third look at how I replaced the cap, and sure enough I had an incorrect connection. Works OK now. I guess my eyes are not as good as they used to be. Appreciate your comments.
Harv
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
There are currently 2649 online users. [Complete List]
» 3 Member(s) | 2646 Guest(s)
