Help me identify a Philco Tropic
Hello,
I've stumbled across a model I cannot identify.
Tubes (those I'm sure of) are: 12AV6, 35W4 and 12BE6 + 2 more.
On a sticker inside says: *39-9339-39 code 122, 40/100 cycles and "importe des etats unis d'amerique".
I have a few pics I may send if anyone can help.
Thank You, Dejan
Can you post the pics here?
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Sometimes the Tropic models are close to the US models. Since we don't often see them here in the US its anybody's guess.
If you are outside the US I might recommend Paul Stennings forum in the UK who seem to have a better handle on the export versions.
There are currently 8418 online users. [Complete List]
» 1 Member(s) | 8417 Guest(s)
