Model 80 schematic clarification
I have one of the production runs of a model 80 that is different from the schematic.
In the notes noting the changes I cannot read the part numbers they are referring to.
anyone have a clearer version besides what is on NA?
Try our own Chuck, best and most readable documentation in Philco Land.
Jerry
http://www.philcorepairbench.com/
There's a schematic on audiophool that more readable. You just need to download the DjVu reader.
Or you can order a full set of info from Chuck Schwark for just a few bucks as mentioned earler. There's some additional 80 info here and here and here.
The Dejavu was what I needed Thanks.
Icon_thumbup
The philco people wrote the wrong part numbers in the "updated parts list" but one can figure it out. They call part 38 part 30
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
