Philco 46-250 code 125
Are they many differences between the code 121 and the code 125? What do the codes represent? One difference is that the one I have (code 125) has a 50B5 tube in it. I have yet to look undet the hood to see what makes her run. I printed up the nostalgia code 121 schematic but was just curious.
thanks
Chris
Yes. I have all the Production Changes for your 1946 model.
See the SCHEMATIC INFO page on my site.
Chuck
There are currently 6853 online users. [Complete List]
» 2 Member(s) | 6851 Guest(s)
