speaker 45C
I am restoring a Philco 45C "Butterfly." It has a dynamic Utah speaker that doesn't look to be original. I see that the field ohms on the schematic is 1140, but it doesn't indicate the diameter of the speaker. Does anyone know the correct speaker setup for this one?
Thanks.
5 inches. A speaker from a 610B tombstone is nearly identical and will fit.
(04-28-2015, 11:36 AM)Ron Ramirez Wrote:  5 inches. A speaker from a 610B tombstone is nearly identical and will fit.
YouDaMan. Thanks Ron.
